Theramsaysuk23
Wifi calling drops out
Hi my wifi calling works for a day or so then drops off.  When I change wifi network it comes back on.  I have full signal on my virgin wifi. Are there any settings in need to update on wifi router?
thanks
japitts
  • 20.7K
  • 2.65K
  • 4.75K
Re: Wifi calling drops out
Who is your mobile network provider?
I presume you've posted in this forum because you have VM home broadband?
Theramsaysuk23
Yes VM broadband.  Both 3 and O2 mobiles have same issue
japitts
  • 20.7K
  • 2.65K
  • 4.75K
I suspect you'll end up troubleshooting this with 3 & O2? The various networks do have different configs.
Is it only VoWiFi that you have issues with? Does your VM-BB work OK otherwise?
Theramsaysuk23
Yes vm bb works ok otherwise
japitts
  • 20.7K
  • 2.65K
  • 4.75K
There's no settings should need changing in your router, evidenced by VoWiFi working.
If it's dropping off after a period of time, I'd suggest troubleshooting that with the MNO - 3 or O2 in this case.
It would be interesting to see if these are the only MNO affected, or whether VF/EE users are also having issues.
