Wifi call does not work on 3
BiddyBowls
I have used wifi calling numerous times, but since swapping to virgin it no longer works. It connects the call but no one can hear my voice, i can hear them. My wife is also on 3 and it does not work and the same issue.
When looking online it says wifi calling only works on Virgin phones, is there a workaround?
2 REPLIES 2
Legend
We both use Wi-Fi calling over VM internet, It works perfectly & we do not have VM phones.
In the Virgin Media account we do have the Child Safe option disabled.
Login to the Virgin Media online account at : https://www.virginmedia.com/my-virgin-media
Then visit : Account Settings >>> Online Security
Set Virus Safe to OFF ( just to be sure )
Set Child Safe to OFF ( this is the option that is blocking most content )
Thank you so much for the advice, will give it a try 😀
