Alicetom
Wifi boosters
Hi, we’re new to virgin. We have a great service with a 100mb line so are partially happy. However we do have a blackspot at one end of the house, and when i use the Connect app it tells me I need a wifi booster. It then directs me to go and buy one which I’m trying to do but then it seems to get stuck. Had any one had the same issue? Is there another way to buy a wifi booster? Thanks
sophist
  • 2.14K
  • 371
  • 529
Problem sorter
Re: Wifi boosters
i suspect that it's because the wifi pods are out of stock at the moment.
there are 3rd party alternatives.. the VM boosters represent poor value over time.. at £90 over the course of an 18-month contract.. you could get yourself an entry-level mesh system for not too much more than that..
