Just joined
Wifi boosters
Why do the virgin wifi boosters broadcast a different wifi network ID from the HUB 3.
Setup the boosters, can see them via virgin connect app. BUT, no devices have connected to them, everything still connected to HUB 3
Do you have to login to the boosters? I note they have a separate passwords also.
Tags (1)
  • 2.6K
  • 394
  • 537
Trouble shooter
Re: Wifi boosters
Hi richnic63,
Have you paired the boosters with your hub?
Press and hold the WPS button on the larger Wifi Booster for about 10 seconds and release it. The Wireless and Power lights will start to blink.
Press and hold the WPS/Virgin Media button on your Hub until the lights start blinking. The WiFi Booster will start copying your Hub’s details.
When the Wireless light on the WiFi Booster stops blinking and goes off, the copying process is complete. The power light will remain on.
If you have  more than one WiFi Booster you will need to repeat this process for each one.
You should then see the boosters listed in your hub settings (192.168.0.1) under connected devices
Dave
