Wifi boosters
I set up two wired boosters today and at first both connected perfectly then the booster connected to hub started flashing red connectivity light and the second booster started blinking power light. I left this for over an hour then unplugged reset and swapped over the boosters. Same result connects according to the book but then the lights start blinking. Any ideas are welcome
  • 1.28K
  • 88
  • 128
Re: Wifi boosters
Hi Kevin57x5,
Thanks for your very first post and  a warm welcome to the community 🙂
Sorry to hear you've been struggling to get your wired boosters to function properly. When the booster that is connected to the router started flashing, did you notice whether your broadband connection dropped entirely?
Have you tried factory resetting both boosters and performed the set up process again to see if that helped at all? Also, when you initially tried pairing both boosters together, did you have both boosters plugged into sockets in the same room?
Beth
