dukedog
Message 1 of 13
Wifi booster Heat issues
Hello I have recently installed your Wifi boosters and when in use they are running very hot to touch,the back of them generates massive amount of heat. Bit concerned they may cause a fire. Is this a design fault with them that is known about or are they faulty?
Alex_RM
  • 4.48K
  • 258
  • 341
Message 2 of 13
Re: Wifi booster Heat issues
Hi dukedog,
Thanks for posting and welcome to our community 🙂
This definitely shouldn't be happening, are they still over-heating since posting?
Alex_Rm
dukedog
Message 3 of 13
Thanks for reply,yes still running hot,especially the larger wifi booster which is very hot at top or rear,I have moved it to a well ventilated open plug socket. I would say its running about 60-65c + .....be ideal in the winter,save having to put the heating on!!!
Alex_RM
  • 4.48K
  • 258
  • 341
Message 4 of 13
Thanks for confirming 🙂
I've popped you over a private message so I can get a few more details from you to arrange sending a new set 🙂 (purple envelope, top right hand corner)
Alex_Rm
timchristie
Message 5 of 13
Hi I am also have problems with a very hot WiFi booster.  Thanks Tim
Zoie_P
  • 2.91K
  • 137
  • 235
Message 6 of 13
Hi Timchristie,
I am sorry to hear you are having similar issues, I will pop you over a PM and I can send you some new ones out 🙂
thanks
Zoie
dukedog
Message 7 of 13
Think this is a design fault as replacements arrived and installed and running just as hot so keeping unit as exposed as possible with maximum airflow and near a smoke alarm just in case!!!
paulgray
Message 8 of 13
Did anybody manage to resolve this? Our devices get very hot.
Paul
Robert_P
  • 2.94K
  • 149
  • 268
Message 9 of 13
Hello paulgray
We're currently experiencing stock shortages with the Pod's, as soon as they become available again we'll let you know. If you're feeling uneasy about the current Pod and how hot it gets we'd recommend stopping using it, if you do keep using it please ensure it is as well ventilated as possible.
Rob
paulgray
Message 10 of 13
Thanks, Rob. Will do.
