Shery_35
  • 5
Wifi acess point
Can anyone pls recommend a WiFi acess point that easy to set up ive got an ethernet cable running from router virgin hub  .
Thank you
sophist
  • 2.55K
  • 420
  • 683
Re: Wifi acess point
really depends how much you want to spend.. you could opt for something like the archer c6, which is a router rather than an access point, but you can configure it in "access point" mode. it's relatively cheap and should do a decent job.
or you could go for something designed just to be an access point and has no function other than that, unifi gear is excellent, but more expensive.. and of the two is probably a little less intuitive to set up - but it should provide excellent / reliable connectivity.
lotharmat
  • 2.54K
  • 189
  • 462
Trouble shooter
+1 for the Archer C6 (or7)
Doddle to set up and great coverage!
