Message 1 of 7
Wifi Speed Deterioration
My wifi speed has been poor for about a month. I have to reset the box most days, sometimes it gives a short win of speeds back to what they are supposed to be other times the reboot gets it working temporarily until the next crash.  I have tried many times to get through to customer services, seems a good strategy to prevent me leaving giving i cant speak to anyone to resolve the problem or to just leave.  Any ideas?
Tags (3)
  • 24.77K
  • 1.43K
  • 3.15K
Message 2 of 7
Re: Wifi Speed Deterioration
Do wired connections behave the same?
Message 3 of 7
Thanks for the response.  I don’t have any wired devices aside from the smart TV.  After an hour long wait I finally got through to the faults department at virgin and they have agreed to send out a new Hub3 as they think that might the the problem.  Let’s see!
  • 4.42K
  • 748
  • 1.79K
Message 4 of 7
I'll be very surprised if a replacement hub fixes the problem.  Speed connections and reliability problems that are fixed by a reboot are invariably where the hub is losing synchronisation on one or more channels due to a power or noise problem, and those aren't usually cured by swapping out the hub..
Message 5 of 7
Thanks, I will give it a try.  What can I do if this doesn’t work?
  • 11.9K
  • 926
  • 1.53K
Message 6 of 7
Can you please
Mike Robinson
  • 11.9K
  • 926
  • 1.53K
Message 7 of 7
Mike Robinson
