07-05-2022 16:11 - edited 07-05-2022 16:13
I currently have 3 Wifi pods (the new intelligent ones) at my home, one upstairs and two downstairs. Going between them, the wifi connection is never seamless. For example, my wifi call will drop if I go from upstairs to downstairs (funnily enough this happened when calling VM) and if I am on video call, it will say "reconnecting" for a little bit then connect again.
It is very frustrating that in my own home I do not have seamless wifi which the intelligent wifi pods are supposed to address via a mesh wifi network, they do not act like a mesh network.
Any suggestions on how to make them act like a seamless mesh wifi network? (I did try call VM but the advisors were no help and said all they can do is send signals and technicians don't assist with wifi pods)
on 07-05-2022 18:03
It sounds as if there is a break in coverage between the pods. They do need a reasonable overlap in their coverage to allow a proper handover. I would install one of the WiFi signal apps and do a signal strength survey to see if the pods are in the best locations.
on 07-05-2022 18:14
on 07-05-2022 19:17
Have you got the pods in the correct location. For normal use they should be equidistance between the hub and the target machine, not in the same room.
on 07-05-2022 19:41
I have had the pods and yes you are correct if you move around you dont automatically connect to another pod if you signal gets weak, I have had pods from the beta stage and to be honest they arnt the best, but ok for free. They just need to get them working on the Hub 5.
on 07-05-2022 21:15
Why would anybody expect a cheapskate ISP hub, running mesh router emulation software on a puny, underpowered CPU to do the job of a proper mesh system? We're comparing a shonky hub running firmware homebrewed by VM to systems purpose designed by companies who make hardware for a living, know what they're doing, and have a reputation to protect?
The VM pods are pretty good for many people (especially if free). But I'd never expect them to work as well as a proper mesh setup - if people want that, the answer is to buy one. Like I have.
on 26-05-2022 20:58
Ok looking at the thread (which is what I thought I would expect, but wanted to hold off buying :P), I will persue buying my own kit for my house.
What WiFi 6 router and mesh system would this forum recommend? (Can be different router and mesh combinations)
Cheers
on 26-05-2022 21:03
on 26-05-2022 22:07
Thinking of the TP-Link Deco X20, but saw a comment and actually realised the image also shows this, the system isn't a 'true' mesh system as it connects to the base 'router'. Opinions?
on 26-05-2022 22:09
