on 09-09-2023 11:11
Hi, I would like to order a wifi pod as we're on the volts bundle and we have 2 rooms in the house that get under 30Mbps.
We spoke to someone on chat and they couldn't help us order one for some reason.
How else would I go about ordering one?
Thank you!
on 09-09-2023 14:48
See this
________
VM Wifi is now “guaranteed” to 30 Mbps/room it’s now called… Wifi Max See if anything in here helps….
You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible - you are - it is clearly stated on the webpage.
If not free to you… you will be charged £8/month for up to 3 pods (note - BT charge £10/mo for their whole home wifi solution). It’s a simple solution and should work for you. However, you would soon pay off that cost by buying your own wireless solution that will be yours to own and use forever, although the VM Pods should be a simpler option.
If you do want to invest in better equipment, you would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point, (4) a pair of good quality Wifi Powerline Adaptors, or a combination of (2&3).
£40-100 (that’s ~4->12 months of Max Pod rental) should sort it for most customers with an average property and usage. Spend more for additional advanced“features” - if required.
