on 13-10-2023 14:28
One of my WiFi pods makes a loud noise like a fan running inside it and is very warm to touch!
The other one has never made this noise, any one else had this problem? I have uplugged the "faulty" wifi pod in case of fire risk!
on 13-10-2023 16:09
Hi F1nut4 👋
Thanks for posting, and a warm welcome back to the Community Forums.
I'm very sorry to hear about the issue with your Pod. You've done the best thing for now, which is to unplug it. I'm going to send you a private message, so we can look into getting this resolved for you.
Please look out for my message in the top-right, white envelope or by tapping your profile picture and then "Messages".
on 19-10-2023 09:44
I have the exact same issue - got my pod yesterday and it woke me up at 5am buzzing and whirrring like crazy and really hot to touch.
Ive unplugged it but can’t get in touch with customer services?
on 22-10-2023 10:50
Hi Trudy13,
Thanks for using the Community Forums to get this issue with your WIFI Pod looked into, I am sorry if this has been causing some concern 😥 I would be more than happy to look into this for you within a PM which I'll send over now 😊
Speak soon!
Megan_L
on 22-10-2023 11:09
I would suggest that both very serious incidents are reported to Trading Standards https://www.citizensadvice.org.uk/consumer/get-more-help/report-to-trading-standards/
Retain the devices in case TS need to inspect them.
on 24-10-2023 11:12
Thank you for reaching out I can see my colleague is in PM about this already to get this resolved. Cheers
Matt - Forum Team
New around here?
on 25-10-2023 11:06
No that is NOT correct! I am still waiting for a PM!!
on 25-10-2023 11:09
I AM STILL AWAITING YOUR PM 2 WEEKS LATER! WILL I GET A PM ANYTIME SOON????????....
on 25-10-2023 18:30
No
on 28-10-2023 09:42
Hi there @F1nut4
Thank you for popping back and I'll be more than happy to look into this with you, I'll pop another PM across now.
Please keep an eye out for the envelope at the top of your screen alerting you to a new message.
