Wifi Max pods
RHI66
I got wifi in living room and don’t not reach backroom well, I want to order Wifi Max pods but I seems can’t find how to order your website apart from phone number. However I can’t use phone because I’m Deaf.
Any suggestions how I can order wifi pods?
RHI
2 REPLIES 2
Have you tried via the Connect App ?
What package are you on ?   See this...
_______________________________
VM  Pods are only free to customers on the 1GB or Volt (or old Ultimate Oomph) packages - is that you? If so they are worth trying - they should work for you. VM Wifi is now “guaranteed” to 20 Mbps/room it’s now called… Wifi Max
You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible it will be £5 or £8 month - you are… and it wont be - just look on the webpage.
If not free to you… you will be charged £8/month (note - BT charge £10/mo for their whole home wifi solution). It’s a simple solution and should work for you. However, you would soon pay off that cost by buying your own wireless solution that will be yours to own and use forever, although the VM Pods should be a simpler option.
If you do want to invest in better equipment, you would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point (4), (5) a pair of good quality Wifi Powerline Adaptors, or a combination of (2&3).
£40-100 (that’s ~4->12 months of Max Pod rental) should sort it for most customers with an average property and usage. Spend more for additional advanced“features” - if required.
Legend
Just avoid the fight with VM systems, an AC750 dual band Wireless Repeater is £25 from Argos.
