You may be as well refining your Wi-Fi management, it might not fix your problem but will certainly help keeping track of your Wi-Fi frequencies.
Instructions for Hub 3
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name > Add 5 to the 5 GHz Channel name > Click ‘Apply Changes’
Log out of the Hub.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
