Just joined
Wifi Issues - Working from home
I'm working at home at the moment and my Virgin Broadband has been acting up either with random dropouts or low Wi-Fi speeds. I've taken screenshots of my upstream/downstream levels if anyone can help me figure out what's causing the problems.
  • 4.86K
  • 895
  • 1.29K
Re: Wifi Issues - Working from home
Hello
Looking at your stats straight away I can see  two issues, first some of your downstream power levels are above what they should be, and secondly you upstream power levels are right on the MAX, this needs a VM forum staff member to have a look at the backend.
I have escalated this to them to have a look.
Regards Mike
  • 3.25K
  • 135
  • 191
Thank you for the post Louise_Halbert and welcome to our community.
We can see some downstream power level errors so I've used the forum information to book in an engineer appointment for you to fix this.
This is booked for Friday between 8am and 12pm, if you'd like to reschedule this please do this on your online account.
Thanks, Emily.
