martynbeacon
Settling in
Wifi Disconnects randomly
Having this issue where my laptop disconnects for 10-30 seconds multiple times per day. Sometimes it won't reconnect, so I have to disconnect the wifi and reconnect to be able to get back on.
What's causing this as it seems to be an issue for a lot of people?
jimbean
  • 45
Re: Wifi Disconnects randomly
if you find the answer please let me know im having same trouble connecting a tv to wifi thx
martynbeacon
Settling in
I'm kind of hoping someone will post the answer here!
tehwolf
  • 1.56K
  • 253
  • 379
Superfast
Have you (or can you) tested with an ethernet cable? do connections drop over the cable at the same time as the wifi drops happen?
It's worth setting up a BQM to see if the WAN connection is dropping at the same time as the wifi dropouts..
