sharonmac9
Wifi Booster with Ethernet ports
Hi -
does anyone know if the wifi boosters that Virgin Media provide come with 1 or 2 Ethernet connections at the top?
I am working from home and struggling with connections and can't run a 20mtr cable from my router and need to run 2 wired connections.
My other thought was - can I buy a switch to run off of the ethernet connection of the booster if it only has 1 port.
I don't want to sit on the phone for over an hour to ask the question.
thanks
Sharon
tehwolf
  • 1.57K
  • 254
  • 378
Superfast
Re: Wifi Booster with Ethernet ports
@sharonmac9 wrote:
Hi -
thanks
Sharon
VM no longer supply boosters, they have recently launched a wireless mesh solution called “WiFi pods”.  if powerline adapters are the solution you want to use then you’ll have to source your own. Save yourself the phone call and browse your preferred retailers website. 😉
sharonmac9
Hi tehwolf
thanks for your reply - silly question but what are wifi pods and what is a mesh solution - am I able to connect 2 wired devices to these away from the router?
I don't mind what I use - I just need to connect 2 wired devices which don't sit beside the router.
Sharon
tehwolf
  • 1.57K
  • 254
  • 378
Superfast
@sharonmac9 wrote:
Hi tehwolf
Sharon
A mesh system consists of multiple WiFi access points that mesh together to create a wireless network over a larger area than a typical router could provide.
many mesh systems come with a couple of Ethernet ports on each mesh unit so yes, you could attach a couple of wired devices to one if you got one of these.
the vm mesh system does not have any Ethernet ports.
check out the tp-link deco range for a bit more detail..
edit: they are a vastly better solution to powerline booster, in my opinion at least.
  • 15.45K
  • 661
  • 1.51K
Put hub in modem mode with a ZyXEL Multy U by wire and the other where you need it with two ports.
https://www.amazon.co.uk/ZyXEL-WSR30-EU0201F-MULTY-AC2100-TRI-BAND/dp/B07M92TT95/ref=sr_1_3?dchild=1...
  • 20.59K
  • 2.19K
  • 3.63K
If you just want more ethernet ports just get a 5-8 port Unmanaged ethernet "Switch" with GB poorts - these are £15-20 from the usual places - get a good Cat6 ethernet cable to connect it to the Hub too.
