Azzieman
  • 30
Message 1 of 28
Wifi 5Ghz Keeps Dropping
I have a super hub 3 with a 200Mb broadband speed. When I am connected to my 5Ghz wifi signal, I can easily get 200Mb. Which is great, But then everything stops and I have to connect to the 2.4Ghz signal and then I dont get a good speed and everything just slows up.
This is an issue that has started to get worse over the last couple of weeks, and I am wondering if this is a general fault with the hub, and if anyone else has the same issue? And what VM did to resolve this?
At the moment I am on 2.4Ghz because my 5Ghz is not working.  Currently getting 0.66Mbps download on 2.4Ghz.
Aaron
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.95K
Message 2 of 28
Re: Wifi 5Ghz Keeps Dropping
Your device may be looking for stronger signals, try this.
You may be as well refining your Wi-Fi management, it might not fix your problem but will certainly help keeping track of your Wi-Fi frequencies.
Instructions for Hub 3
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name > Add 5 to the 5 GHz Channel name > Click ‘Apply Changes’
Log out of the Hub.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
Azzieman
  • 30
Message 3 of 28
Thanks MikeRobbo,
I already added the 2 and 5 at the end of each anyway. But I have just done the disable optimisation, so will see how I get on.
Thanks again. I will update the post after I have tested it all out 🙂
TR51
  • 22
Message 4 of 28
Hi, any joy on this? I have the same problem.
like yourself I made the same steps but the problem is still present and seems to slowly be getting worse.
Azzieman
  • 30
Message 5 of 28
No. Those options didn’t work and I still had the same issue. My issue was down to my antennas degrading and becoming problematic. My router has since been changed and the issue has gone.
TR51
  • 22
Message 6 of 28
Thanks, I think I need the same, my router must be 5 years old.
unfortunately VM support just keep asking me to switch it off and on again and do the pin reset but not much more 😞
gary_dexter
  • 31.31K
  • 1.94K
  • 4.21K
Message 7 of 28
What hub is it?
TR51
  • 22
Message 8 of 28
Hub 3
gary_dexter
  • 31.31K
  • 1.94K
  • 4.21K
Message 9 of 28
So the current hub (bar the Hub4 for Gig1 customers only).
Have you explored getting your own router or mesh system to improve the WiFi?
TR51
  • 22
Message 10 of 28
No, I haven’t. When it’s working it works fine. I believe it’s just deteriorated due to age.
literally just signed a new contract in the last few days too!
