Wayne_
Message 1 of 7
WiFi
I added 4 new devices (Nest Speakers) to my WiFi, They work but the ones furthest away from the router keep dropping out. Other device connections furthest away used to have some issues but now they stop working when in the same room. I can still access the internet but when I try and do something which uses more data I have to turn the WiFi on my mobile off just to play a game or I have to turn the speaker off and on to get it working again.
The Virgin Media Connect app does not work so I can't do any scnas to hopefully request the free Pods, it keeps saying not connected when it is.
I am pretty sure it is a Hub 3.
I have done a WiFi scan and fixed the channels at clear bands on both the 2.4G and 5G.
What can I do?
Also, does it wind anyone else up that virgin think WiFi is thought of as part of the broadband.
Cheers,
Wayne
  • 6.8K
  • 591
  • 1.78K
Message 2 of 7
Re: WiFi
VM only guarantee a wifi speed of 20Mb as wifi is very susceptible to interference.
You need to use the Connect app to identify wifi blackspots and the app will then allow you to order one Pod.  It is a bit flaky so just persevere and it will work eventually.
Note if you have split the SSID on your Hub, it will need reset to factory settings for the Pods to work.
If you wait here a day or two a VM Mod will pick this up to discuss.
Wayne_
Message 3 of 7
Re: WiFi
Thanks for the reply.
I have and do keep trying the app but it just says I need to connect when already connected.
It did work when I first installed and managed to run 2 scans 🙂
I installed it on another mobile and it says I need to connect on that as well.
I am not convinced it will show less than 20Mb either in any of the rooms. Seems more of a issue where the Hub can't handle that many devices.
Cheers,
Wayne
Carley_S
  • 3.1K
  • 163
  • 263
Message 4 of 7
Re: WiFi
Hi @Wayne_
Welcome to the community forums.
Sorry to hear that you're having issues with your WiFi and connecting your devices further away. I have check the system at our side and cannot see any area concerns, or issues with your power levels at all.
What I have seen is that your 2.4 band isn't on the best channel, we would normally recommend channels 1, 6 or 11. The reason for this could be that you have turned off channel optimization and have made changes to your WiFi network settings.
I recommend performing a 60 second pin hole reset on the router. This will revert any customisations back to factory settings and full update the router with firmware/software updates. Please do not reboot the router whilst it is completing the pin hole request.
Once this is completed, without changing any settings, please try the connect app in the room where you are experiencing the issue. You can also perform a speed test in any rooms you find blackspots.
When you're in the room where the issues are, does the device pick up the WiFi signal at all or does the connection slow/drop outs intermittently?
Please can you run a Sam Knows speed test on a PC / Laptop / SmartPhone / Tablet from the room(s) you're experiencing speed issues in and let me know the results. When you run the checks, please ensure you do not have a VPN enabled or have other devices actively using the internet connection at the time of the test i.e streaming / downloading / gaming etc
Carley - Forum Team
Wayne_
Message 5 of 7
Re: WiFi
I reset the router and ran the test.
Connection seems to be a little better but the speed was 16Mb
The app still doesn't seem to offer any option to order any pods.
Wayne
Molly_T
  • 1.9K
  • 62
  • 184
Message 6 of 7
Re: WiFi
Hi Wayne 👋! Thank you for getting back to us.
I'd be interested to know if the Connect app was recognising your hub again following the pinhole reset?
Sorry to hear you are still not able to order your pod via this method though. I will send you a PM 📩 to confirm a few details and give you a hand with this initial pod order. Please do be aware we can't help with 2nd and 3rd Pod orders via community as they require live diagnostics. But these can be ordered via the connect app and by phone on📞 0345 454 1111 or 150 from a VM landline.
I will also just mention that you need to have Wi-Fi optimization with the band's un-split for the Wi-Fi Pod's to work.
You can find the PM in the top right corner of the page in your Inbox, we can return to this piblic thread with a further update when possible.
Thanks for your patience in the meantime! All the best. 🌞
Molly
Molly_T
  • 1.9K
  • 62
  • 184
Message 7 of 7
Re: WiFi
Hi All! 👋 Just returning to this public thread to keep it updated.
We were able to help order the initial Wi-Fi POD for Wayne - thanks to them for PMing with me and confirming a few account details to make this possible! 📩
Hopefully this resolves the issues with the Wi-Fi coverage, but if you do need further support with an additional Wi-Fi pod following this you will need to complete live diagnostics so another can be sent. You can do this via the connect app 👉 https://virg.in/connectapp or by phone by calling us on 📞 0345 454 1111 or 150 from a VM landline.
Please feel free to return to this thread to let us know how you get on with the initial POD.
Wishing you all the best. 🌞
Molly
