WiFi
I have had no broadband for the whole day I work at home so need it earlier it said there was an issue in my area but now saying it's ok but i still can't connect have tried to ring but can't get through anyone else having issues still
  • 24.89K
  • 1.44K
  • 3.17K
Re: WiFi
Have you rebooted the hub?
  • 12K
  • 934
  • 1.53K
Re: WiFi
Try a reboot to see if the Hub can renegotiate a better connection using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your connection again.
Mike Robinson
  • 1.69K
  • 103
  • 170
Re: WiFi
Hi Gill,
thanks for using the forums to get this issue looked into with your broadband, I am sorry if its been causing you some frustration.
Usually what we would ask you to do is just follow these links in order to try and resolve it before we have a look-
Slow Speeds Help
Intermittent Connection
Can't Connect
We may also ask you for a bit more information so we can understand your specific issue like have you checked your speed using our Speed test site here. We also like customers to use a BMQ graph to gain more of an insight into your HUB's performance. We also may need to you reboot your HUB so that the data on the HUB's logs can reset, this helps the performance and also helps us identify any issues on our side.
Please let me know how you get on with this information.
Megan_L
