I've got hub 3 and I also use powerline adapter for work in the loft.
Since last week, maybe 2 weeks ago, it's been intermittently cutting out, at times it is so weak on the powerline that it fails to connect to my work server via vpn.
Literally nothing has changed, we hadn't gone near the router, we don't mess around with the wires, nothing like that.
I've done the virgin media status check and the test shows there's no problems. I've done a reset of the hub, but still no luck.
At times it works fine as if nothing is wrong , but when joining teams meeting at work, it is slow, keeps cutting out and basically unbearable so I join meeting via calling in directly from my phone.
Same problem with my Mrs when she's working from home too, so I could rule out my phone and my laptop being the problem.
When using Netflix or prime videos, it can hang too at times.
Is there any suggestions or ideas please.
Much appreciated.
Ta
