MCatchpowle
  • 5
WiFi sudden not discoverable
Several of my devices are not able to find my Wi-Fi box suddenly today. The Wi-Fi box is not coming up as discoverable on several platforms.
I also have a Wi-Fi booster which cannot connect to the Wi-Fi.
Only two devices in the house are still connected to the Wi-Fi.
I have tried a master reset of the WiFi hub router with no luck.
g0akc
  • 902
  • 84
  • 173
Well-informed
Re: WiFi sudden not discoverable
Check to see if the hub network name (SSID) has changed.
See if there’s a different SSID present and/or login to the hub and see what it is set to.
A free WiFi analyser app may help.
Any devices still connected may be using to old/original default SSID which they have remembered.
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
MCatchpowle
  • 5
How do I check if the SSID name has changed?
Thank you.
lotharmat
  • 947
  • 70
  • 142
Well-informed
Have a look in the hub settings pages
Browse to 192.168.0.1 and login to the hub.
Look in the wireless tab and see what's there!
