on 09-11-2020 17:12
I just upgraded from 350mb to 500mb
WiFi range is weak and intermittent
Should I ask for hub 3 to be replaced to hub 4
Answered! Go to Answer
on 08-08-2021 10:17
Does anyone have this particular model.? Do the nodes have to be in range with the parent node or can a node be in range with another node to increase the lateral coverage of the house.?
on 09-08-2021 09:27
Anyone know whether this supports daisy chain?
on 11-08-2021 09:35
Hello happytre3frendz
Thanks for taking the time to raise your query via the forums. We aren't able to comment or offer any support or advice on third party equipment I'm afraid.
We would recommend visiting the manufacturer's website for more information or their contact details who will be able to assist you with this further.
Rob
