zm1
  • 17
Message 31 of 43
Re: WiFi signal & range weak
Too technical for me
From what I remember - the Velop System is mixed (so I assume that's both)
I'm going to see how stable the connection is or whether it drops (it did a lot of that previously when I had no Mesh system connected - however the Mesh System has made it more stable)
I still have no idea why the Engineer failed to come yesterday - but that's a different issue
happytre3frendz
  • 50
Message 32 of 43
Ok I am really confused with this prodocut
I want to purchase only if the virgin hub can be placed into MODEM only mode. SOme say they can do it howver some say its not possible
https://community.virginmedia.com/t5/Forum-Archive/Velop-Mesh-Wi-Fi-System/td-p/4283189
See above link
This is because the Linksys WHW0303 Velop Tri-Band Whole Home is a mesh but NOT actually a router so it has to be used alongside another router.
What is the answer?
  • 17.08K
  • 732
  • 1.71K
Message 33 of 43
The Linksys WHW0303 Velop can by a router so you can use modem mode. The auto-sensing is bad as it will go to 192.168.100.2 as the modem mode boots up before the Velop gets the WAN IP.
happytre3frendz
  • 50
Message 34 of 43
Right
Thanks for clearing that up. The confusing part is that they are all identical and its not clear which is the main node to be plugged into the modem
There is no WAN port. I see some reviews on amazon saying plug the main node into the modem. I am thinking about purchasing a 2nd hand system on ebay and the guy selling it said they are all identical.
So i am just a bit hesitant
happytre3frendz
  • 50
Message 35 of 43
Ok so i checked the specs
It says
2x WAN/LAN auto-sensing Gigabit Ethernet ports
Can i just confirm they are all the same so each unit has 2x WAN/LAN auto-sensing Gigabit Ethernet ports
There is no parent or master unit that has to be used?
  • 17.08K
  • 732
  • 1.71K
Message 36 of 43
They should be the same...
happytre3frendz
  • 50
Message 37 of 43
Strange.
Every other mesh system has a dedicated WAN (INTERNET) port so its clear that it is a router.
  • 17.08K
  • 732
  • 1.71K
Message 38 of 43
Why not get a wireless router?
happytre3frendz
  • 50
Message 39 of 43
Huh?
I dont get your response. This is a router with a mesh system. The whole point for the mesh is to get good coverage of the whole house.
happytre3frendz
  • 50
Message 40 of 43
Does anyone know what the difference is between the whw03 and the whw03v2
The v2 has something like gigaclear associated to it.
What's that
