WiFi sender
I have the Super Hub 3 and I'm trying to connect the wifi on to TP-Link TL-WA854RE Extender.
Question: When I depress the WPS button on the front of the Hub should it flash?
  • 24.77K
  • 1.43K
  • 3.15K
Re: WiFi sender
Setup the extender manually using the web gui rather than WPS
Re: WiFi sender
Thanks for the quick answer. Any reason why I should do it manually?
  • 24.77K
  • 1.43K
  • 3.15K
Re: WiFi sender
WPS can be unreliable sometimes
