  • 9
Message 1 of 20
WiFi problems
We’ve been having problems with our WiFi for quite a while, connection is intermittent, speeds are up and down. We have problems trying to watch movies/YouTube/gaming. Partner is working from home which has been affected at times with speeds of under 1mbs when our package is 500. Diagnostic test says “Your home network has a few problems. Checked the router status and this was the report ... if anyone could give some advice or help that would be appreciated! Thank you
12590000003.737256 qam16
21390000007.538256 qam1
31470000009.338256 qam2
41550000006.538256 qam3
51630000008.538256 qam4
6171000000638256 qam5
71790000008.438256 qam6
81870000004.938256 qam7
9195000000838256 qam8
102030000003.737256 qam9
112110000006.837256 qam10
122190000003.537256 qam11
132270000004.937256 qam12
142350000003.237256 qam13
152430000003.737256 qam14
162510000002.737256 qam15
172670000002.737256 qam17
18275000000437256 qam18
192830000003.736256 qam19
202910000003.237256 qam20
21299000000537256 qam21
223070000002.237256 qam22
233150000005.537256 qam23
243230000001.437256 qam24
1Locked37.650
2Locked38.680
3Locked38.900
4Locked38.6150
5Locked38.900
6Locked38.6130
7Locked38.900
8Locked38.6130
9Locked38.9130
10Locked37.600
11Locked37.600
12Locked37.380
13Locked37.600
14Locked37.300
15Locked37.650
16Locked37.370
17Locked37.600
18Locked37.660
19Locked36.620
20Locked37.300
21Locked37.600
22Locked37.310
23Locked37.600
24Locked37.900
11/11/2020 09:23:6noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:22:33Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 02:06:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 02:05:3criticalREG RSP not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 02:05:3ErrorT6 Timeout and retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 02:05:3criticalRegistration RSP rejected unspecified reason;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 01:44:25noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 01:33:7noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 01:33:7ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 01:30:19noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 01:01:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 01:01:18criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 01:01:10criticalDHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 01:00:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 00:59:58Warning!B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 00:57:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 00:57:32Warning!B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 00:56:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 00:56:28Warning!
  • 24.46K
  • 1.4K
  • 3.11K
Message 2 of 20
Re: WiFi problems
What are your wired speeds like?
  • 11.56K
  • 823
  • 1.64K
Message 3 of 20
Re: WiFi problems
Your singals are in spec, but there is a large diffrence between 139mhz and 323mhz. I supsect when you get up to 715mhz for tv they will be well into the negatives. Is your TV pictures okay?
I work for Virgin Media and my posts are my own opinions
  • 9
Message 4 of 20
Re: WiFi problems
Wired speeds at the moment are 378.8 but it can change in an instant
  • 9
Message 5 of 20
Re: WiFi problems
Picture is okay at the moment but last week we had to run videos in 360p, couldn’t do 1080 or 4K at all and sometimes the films just wouldn’t load. It fluctuates constantly and gaming online tends to be jittery also.
  • 11.57K
  • 898
  • 1.48K
Message 6 of 20
Re: WiFi problems
Can you post your Upstream data please.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 11.57K
  • 898
  • 1.48K
Message 7 of 20
Re: WiFi problems
Mike Robinson
  • 9
Message 8 of 20
Re: WiFi problems
1537000094.325512064 qam2
2394000144.325512064 qam4
3461999914.325512064 qam3
4602999764.325512064 qam1
3ATDMA0000
4ATDMA0000
  • 9
Message 9 of 20
Re: WiFi problems
Okay I’ll do that now. Thank you
  • 9
Message 10 of 20
Re: WiFi problems
My BQM
