  • 10
Message 1 of 17
WiFi poor and intermittently drops
I’d say over past 3/4 months my Sufi has declined in performance and drops intermittently. Any suggestions?
  • 12.24K
  • 948
  • 1.57K
Message 2 of 17
Re: WiFi poor and intermittently drops
What is a 'Sufi' ?
Mike Robinson
  • 25.12K
  • 1.44K
  • 3.2K
Message 3 of 17
Do wired connections also drop?
  • 10
Message 4 of 17
Not as far as I can see, don't have many wired
  • 10
Message 5 of 17
Oops - Wifi
  • 25.12K
  • 1.44K
  • 3.2K
Message 6 of 17
Difficult to ascertain the issue then.
Do the lights on the hub change?
  • 12.24K
  • 948
  • 1.57K
Message 7 of 17
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Mike Robinson
  • 10
Message 8 of 17
1 299000000 3.2 38 256 qam 21
2 203000000 3.2 38 256 qam 9
3 211000000 3.4 38 256 qam 10
4 219000000 3.4 40 256 qam 11
5 227000000 3.5 38 256 qam 12
6 235000000 3.4 38 256 qam 13
7 243000000 3 38 256 qam 14
8 251000000 3 38 256 qam 15
9 259000000 3 38 256 qam 16
10 267000000 3.2 38 256 qam 17
11 275000000 3.2 38 256 qam 18
12 283000000 3.2 38 256 qam 19
13 291000000 3 38 256 qam 20
14 307000000 3 38 256 qam 22
15 315000000 3.5 38 256 qam 23
16 323000000 3.7 40 256 qam 24
17 331000000 3.4 40 256 qam 25
18 371000000 3.5 40 256 qam 26
19 379000000 3.7 40 256 qam 27
20 387000000 3.4 38 256 qam 28
21 395000000 3.5 40 256 qam 29
22 403000000 3.7 40 256 qam 30
23 411000000 4 38 256 qam 31
24 419000000 3.7 40 256 qam 32
1 39400000 43.8 5120 64 qam 4
2 46200000 44 5120 64 qam 3
3 32600000 43.5 5120 64 qam 5
4 25800010 42.8 5120 64 qam 6
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
25/10/2020 16:33:9 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:37 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 14:20:49 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 14:20:39 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 13:57:34 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/10/2020 17:22:9 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/10/2020 13:26:6 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 19:26:21 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 16:53:15 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 16:38:37 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 16:36:34 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 15:26:49 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 14:58:58 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 14:34:58 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 13:50:35 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 11:35:34 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 11:29:38 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 11:24:8 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 22:24:4 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 16:14:18 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 4.48K
  • 265
  • 473
Message 9 of 17
Hi Andersond150,
Thank you for reaching out to us in our community and a warm welcome to you, I am sorry to hear issues with an intermittent connection.
I have had a look at thing our end and cannot see any issues at all, I can see you have since spoken to us and was suggestion to reboot your router, have you had any further issues since this.
If you are still having issues I would advise you to set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any network dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with us. Make sure you uncheck the “ignore ping from WAN side” box in the settings if you see a wall of "red" - note it will take an hour or two to start seeing a sensible picture. please run this for 72 hours and post the results here so we can have a further look into this for you.
Paul.
  • 10
Message 10 of 17
Im convinced this is a router problem - Ive been having it more gradually for months. Im about to change provider as I cant stand the probelm, nor the trouble getting support from virgin.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/f497b015e9be63b4557fbb1b9bc64bd8384675f0
