on 22-03-2022 15:24
I have one of WiFi pods connected to the router via Ethernet the router in in the living room while the pod is in the garage. It provides great WiFi to the room above the garage.
does the pods provide better wifi than the hub 3?
Answered! Go to Answer
on 25-03-2022 21:57
on 24-03-2022 15:32
on 24-03-2022 15:43
Thanks for the reply.
I understand that. What I’m asking is the signal on pod stronger than Router?
kind regards
serkan
on 24-03-2022 15:57
“does the pods provide better wifi than the hub 3?” It’s not a question that can really be answered as VM do not make information available. What you would need to know is the power of the radios in both as well as number of antennas and where they are placed in the units. All this also assumes the pod is connected by Ethernet to the hub, as I believe yours is.
on 25-03-2022 12:30
What I don't get is how can pods make thing better if the wireless is poor on the hub then connecting to the pod is just as bad to the hub
on 25-03-2022 14:43
“What I don't get is how can pods make thing better if the wireless is poor on the hub then connecting to the pod is just as bad to the hub”
The OP has the pod connected to the hub with an Ethernet cable. They are asking a valid question, but not one that can be answered access to the technical details of the VM kit which will not ever be available.
on 25-03-2022 21:57
on 30-03-2022 07:39
As Tudor mentioned. The question is due to the information not being available. The Ethernet connection from router to pod is the best way to go. The router wifi is very poor and connnecting pod to router via wifi will mean using the router wifi.
The pods work quite well and the WiFi is good in more than just the room they are placed in, unlike the router which only offers good wifi in the room it’s placed in.
