WiFi pods not working
Jeanne66
We have 2 wifi pods that are no longer working. Rebooted router and moved pods to same room as router but both continue to flash white. Please help
4 REPLIES 4
Legend
Have you recently had a Hub replaced ?
Or recently changed any of configuration or Wi-Fi settings of an existing Hub ?
Nothing has changed.
Legend
Report it as fault.
Reece_MH
Hi Jeanne66 👋
Thanks for posting, and a warm welcome to the Community Forums.
I'm sorry to hear you're experiencing problems with your WiFi Pods. I've taken a look on our side, and can see a short-term issue has been identified which may cause intermittent or performance-related issues with your connection - in turn, causing the Pods to disconnect. These short-term issues can happen when we’re working to fix some other network issues in the area, or when we install a new home to our network.
These intermittent issues can take up to around 24 hours to resolve - so please do let us know how things are later this evening, as we'll be able to run further checks to see if any other problems are found.
Reece - Forum Team
New around here? To find out more about the Community check out our FAQ
