Triciapo
Message 1 of 7
WiFi pod
i received the WiFi pod from Virgin. I plugged it in two days ago and the white light just flashes on and off! The app keeps saying it can’t find the pod! Am I doing something wrong?
thank you.
BenMcr
  • 22.84K
  • 2.52K
  • 4.86K
Message 2 of 7
Re: WiFi pod
Does it still do it when it's in the same room as the Hub?
Triciapo
Message 3 of 7
Re: WiFi pod
It’s in a different room to the hub.
BenMcr
  • 22.84K
  • 2.52K
  • 4.86K
Message 4 of 7
Re: WiFi pod
Ok, but the reason for the question is whether it's a range issue between the Pod and the Hub or a configuration issue.
If it completes boot up in the same room as the Hub then it's a range issue - remember that the Pod needs to go in between the Hub and where you're having an issue, not in the same room otherwise it'll also have an issue.
Martin_N
  • 8.87K
  • 371
  • 536
Message 5 of 7
Re: WiFi pod
Hi Triciapo,
Thank you for your post and welcome to the community.
I'm very sorry for any issue you're having with your WiFi pod.
Can you please try the pod in the same room as the hub?
^Martin
Triciapo
Message 6 of 7
Re: WiFi pod
Hi Martin
ive managed to get it working
Thank you
Chris_W1
  • 6.54K
  • 274
  • 438
Message 7 of 7
Re: WiFi pod
HI Triciapo, thanks for the message and welcome back to the forums.
I am glad that it is now working and please do let us know if you need anything further
Chris
