on 09-10-2023 13:10
Our WiFi pod was flashing blue, so a technician came out and replaced our hub 3 with a hub 5 and also ordered a new pod. The new pod has arrived and is working fine. The old pod still does not work, is there a way to get it replaced as it's still not working? I don't mind sending it back as long as it's obviously taken off of my account.
on 09-10-2023 16:34
Probably the old pod is still "associated" with the Hub3. It will need changing on your account to be activated to the new Hub.
Call the equipment activation number on - 0800 953 9500 (option 3) – you will need the Model numbers, serial numbers/MAC addresses off the barcode stickers of ALL pieces of kit and also your account number
on 11-10-2023 19:47
Hi Dawsons,
Thank you for your post and welcome to the community.
Have you been able contact into the team to replace the pod?
^Martin
