AliRobertson93
WiFi only works in living room in flat.
Hey,
I rent a 2 bedroom flat and our Wifi only works in the living room where the router is. Have a booster in the hall but helps nothing.
How do I fix this?
Many Thanks,
Ali
-tony-
  • 16K
  • 1.26K
  • 3.77K
Re: WiFi only works in living room in flat.
have you split the wifi bands and turned off smart wifi - thats the 1st thing to do on the hub - after that download a wifi analyser - inSSIDer for a pc or similar on a mobile device look at what other routers are around you - look at what channels they are using and choose one that is not busy
____________________
Tony
AliRobertson93
Sorry this doesn't mean much to me. Could you explain a little more? I am not very good at technology.
Thank you for replying to me 🙂
