  • 6
Message 1 of 9
WiFi network
Hi all, I have been having issues with WiFi recently. My speed testing has been about 32 but should be 350! I went into the settings on VM app and noticed I have a connection named just number ‘1’. I connected to this with my password and my connection is up to 380! I didn’t create this connection. Any answers please? Thanks
  • 24.72K
  • 1.43K
  • 3.15K
Message 2 of 9
Re: WiFi network
What do you mean number 1?
Where are you seeing that?
  • 6
Message 3 of 9
Re: WiFi network
Screen shot of mobile WiFi settings.
  • 6
Message 4 of 9
Re: WiFi network
Not sure the screen **bleep** is going through. On my mobile, WiFi settings, networks, I have a section names ‘my networks’ and the network named ‘1’ is in there. I have also logged on to my hub3 and it is showing there too. Thanks
  • 6
Message 5 of 9
Re: WiFi network
Sorry, screen shot !! 😳
  • 1.98K
  • 67
  • 841
Super solver
Message 6 of 9
Re: WiFi network
Network 1 is just a default name.  I'm on Network 2 which was used to set up the computer when I bought it.
The only winning move is not to play.
No system is 100% secure
Ridicule is nothing to be scared of - Adam Ant
The only thing constant - is change. Chris Evans
The internet is a series of tubes
Windows Update isn't rocket science - if it were, it would work.
Unlike Monty Python, spam is never off.
  • 6
Message 7 of 9
Re: WiFi network
Ok thanks, but still not sure how this appeared, my default network is the VMxxxxxx network, I have not created the ‘1’ network (it wasn’t there before).  My speeds are much faster on the ‘1’ network and no longer very good on the usual default network? My hub3 says the VMxxxxxx network is 2.5G and the ‘1’ network is 5G. Should I just stay connected to ‘1’ ? Thanks
  • 24.72K
  • 1.43K
  • 3.15K
Message 8 of 9
Re: WiFi network
You can rename “1” to something else if you wish.
  • 6
Message 9 of 9
Re: WiFi network
Ok, thank you very much 👍
