Nickbbbbbb
WiFi network hub 3 and booster
After a long power cut the WiFi booster reverted back to its own wifi network and password.
I have managed to change the hub 3 network to the same name/password as the booster.  Obviously I was aiming to set the booster to sync with the hub 3.
How do I revert to original network name password on the hub 3 and set the booster to this .
  • 23.98K
  • 2.54K
  • 4.36K
Re: WiFi network hub 3 and booster
You usually do a Hub reset as per this...
_____________________________________
With the Hub switched "on", disconnect any ethernet connections (leave the co-ax connected) and then push in the “reset pin” with the end of a paperclip/thin nail/SIM tray “tool” or similar (bigger items like ball point pen ends may not press it in far enough) until you feel it at the “stop point” and hold it there firmly for a "timed" minimum of 60 seconds do NOT manually restart the Hub at any time. Leave it 10' or so to stabilise and then your passwords/passphrase for both the Hub settings and the Wifi networks will revert to the two printed on the Hub sticker on its base/side/card. Make sure you use the wifi one for devices connecting to the wifi and the settings/admin one to access the Hub
See if that sorts it.
Gareth_L
  • 6.92K
  • 424
  • 779
Hey Nickbbbbbb
Quick message to see how things are after the reset
Hoping from no reply its fixed now
If not please let me know
Gareth_L
