WiFi light flashing green constantly
I currently own a Netgear super hub 3 for well over 3 years now running fine one 100mbs everything set to default settings etc today I had a power cut and for some reason upon super hub being powered back on again it’s now running slow WiFi with a green WiFi icon flashing constantly and a static white light at the bottom of the WiFi router I have tried a restart and factory restore and changing the WiFi channels with a reboot nothing worked I’m stuck for ideas anyone else had this issue before
  • 11.39K
  • 790
  • 1.61K
Re: WiFi light flashing green constantly
Its a common bug having a flashing wifi symbol, it has no effect on the connection and one day will just dissapear
I work for Virgin Media and my posts are my own opinions
I found going into the hubs settings and turning the wps button off on the hub manually in settings restarting the hub and enabling it again seemed to do the trick  It appears the hub 3 gets stuck looking for wps devices from what I read up on but thanks for your reply’s
