WiFi light and baselight green and internet light flashing
As stated both the WiFi and baselight are solid green whilst the broadband light is flashing.
My WiFi is not working.
I have tried restarting and resetting the router.
  • 15.53K
  • 1.62K
  • 2.65K
Re: WiFi light and baselight green and internet light flashing
Does this help with any clues ?
https://www.virginmedia.com/help/virgin-media-what-do-the-lights-on-your-hub-mean#hub3
The only thing it could be from that is an update, but if so it's a very long update.
  • 15.53K
  • 1.62K
  • 2.65K
EDIT:  Forgot to ask - can you connect to the Net with a device connected to the Hub by ethernet cable?
Is it a new Hub3 ?
You could try the reset – EXACTLY this way.
With the Hub "on" push in the pin on the back/side/bottom of the Hub with the end of a paperclip until you feel it at the “stop point” and hold it there firmly for a "timed" 60 seconds do NOT restart the Hub after that. Leave it 5' or so to stabilise and then your passwords/passphrase for both the Hub settings and the Wifi networks will revert to the two printed on the Hub sticker on its base/side/card. Make sure you use the wifi one for devices connecting to the wifi and the settings one to access the Hub.
