WiFi keeps going off
My WiFi has been randomly going over the the last couple weeks and is getting worse sometimes goes off 3 or 4 times in an hour, I’ve reset modem many times! I can’t get through to virgin at all. I was on hold for well over an hour today and got cut off, this is driving me crazy!!!!
  • 11.81K
  • 925
  • 1.52K
Re: WiFi keeps going off
What is your connection like using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
Hi thanks for your reply, it makes no difference if devices are connected with cable or WiFi, the modem literally seems to be rebooting literally every 10 mins the green light flashes then WiFi comes back on !! Really annoying
  • 11.81K
  • 925
  • 1.52K
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Mike Robinson
