WiFi issues
My white virgin box is showing a green light with flashing green power.... I have turned off, pressed the reset button etc but nothing is changing.
on devices it says connected with weak security and isn’t letting me connect to use internet.
Any advise welcome as need to do zoom calls with work
thanks
  • 24.56K
  • 1.41K
  • 3.12K
Re: WiFi issues
Does a wired connection work?
