60-70 isn't bad at peak times. Are you connecting on wifi on the 2.4GHz band or the 5 GHz one. Or is there just one SSID?
You could try separating the SSID's of the 2.4 and 5 GHz wifi bands and switching off "channel optimisation" - that often helps Hub3 users get better wifi performance - but its still no substitute for your own better kit.
Also what are connections like on an ethernet cable connection?
