  • 6
Message 1 of 10
WiFi hub 3 dropping randomly
Been reading these forums and everyone seems to kind of have the same problem more or less..
I don’t know what speed I was at before but I upgraded to M299 fibre broadband a couple of months back and that’s when our problems started
We can go days working fine and days when it would drop 3 to five times a day. we live in a two flat bedroom - no stairs
At the start I use to call virgin and they said restart hard your router - now I don’t call them and just do the pin restart. I always check the virgin media app WiFi signal and it will say good service
Last few days signal won’t reach out hallway and that’s literally ten steps from where the router is. We haven’t changed it’s position nothing has changed apart from the upgrade so feeling very frustrated. Am not tech savvy so reading the forums about pinging the signal or changing the channel have no idea what that means
Any plain or step by step advice would be appreciated- in the mean time I am reluctantly buying a WiFi booster (two) even though I believe I don’t need this !! As virgin are saying my hub 3 is working perfectly fine
  • 11.74K
  • 915
  • 1.51K
Message 2 of 10
Re: WiFi hub 3 dropping randomly
The Hub may very well be working fine, it could quite easily be some kind of interference causing your Wi-Fi woes.
Lets look at your connection ...
Mike Robinson
  • 11.74K
  • 915
  • 1.51K
Message 3 of 10
Can you please
Mike Robinson
  • 6
Message 4 of 10
https://www.thinkbroadband.com/broadband/monitoring/quality/share/340cb7544f015dcd4711bc50a47930e98ef2d5d3
I think I posted this correctly - please let me know if it’s not live. I want to say thanks so much for taking the time to reply
  • 11.74K
  • 915
  • 1.51K
Message 5 of 10
It looks OK, it just needs to populate now.
Mike Robinson
  • 6
Message 6 of 10
Just checked the network status -> network log for our router and there area number or errors , critical and warning saying synchronise failed, partial service and time outs - would take a screen shot but it has our MAC address and what devices etc
  • 17.34K
  • 1.82K
  • 3.02K
Message 7 of 10
Your BQM is a wall of red. Either your i.p. is incorrect in its settings (perhaps it changed recently?) or you Hub is set not to respond to pings - try this -
• Navigate to routers web interface
• Advanced Settings > Advanced > Ping > Respond to ICMP echo requests sent to WAN IP
  • 6
Message 8 of 10
we changed the settings last night as per my post (above your post) my partner and I have read some forums with the recent upgrade of the IOS it has affected dropping of wifi on apple products which would explain losing connectivity on our phones from the Hallway but unfortunately it hasnt fixed the issue
also i tired to look for the above - all i have is advanced settings > wireless * security* DHCP * Tools > ping . target (than i need to enter IP address) unsure if this is that
  • 6
Message 9 of 10
Sorry what is modem mode? does that mean attached to the ethernet cable?
  • 3.58K
  • 211
  • 275
Message 10 of 10
Hi Meralie,
You can see how to put the hub into modem mode here
Alex_Rm
