Message 1 of 9
WiFi help needed
Hi where a family of Five and we have loads of tech in the house multiple iPads, I phones, Xbox, PlayStation, alexas all over the house but we are struggling to get things working. My guess is because we have around 20+ items connected at any time.
Would getting another router be better, one that can hold more items?
If so what’s the best router to buy?
  • 25.23K
  • 1.45K
  • 3.21K
Message 2 of 9
Re: WiFi help needed
Possibly yes.
What your budget? Coverage required?
Message 3 of 9
hi the budget can be what ever it needs to be, I’ve seen that a new router can cost up to £300 but don’t really want to splash out as I don’t know if this will help.
the house is a new build house 4 double bedrooms
thanks fo your help with this
  • 25.23K
  • 1.45K
  • 3.21K
Message 4 of 9
You can go 3 ways;
1. Standalone router
2. Mesh system
3. Wireless Access Points (requires you to run lengths of cabling from the hub)
Message 5 of 9
Thanks Gary
what would be your best way of dealing with this? And what routers would your recommend?
Message 6 of 9
If it's just coverage you are after, then wifi extender(s) would solve the problem. However, it's more likely that you will need more bandwidth than you currently have available, if it's connection speeds that are the issue.
Message 7 of 9
A wifi extender does not necessarily have to be cable connected - depends on the model.
  • 25.23K
  • 1.45K
  • 3.21K
Message 8 of 9
That’s why I said Access Point, not Extender.
  • 25.23K
  • 1.45K
  • 3.21K
Message 9 of 9
@Bluespiderman wrote:
Thanks Gary
Any mid-high end ASUS or TP-Link router would work.
But depending on coverage of the house a Mesh system might be the better option.
