Hi bhoughton,
Thanks for coming back to us on this one.
Checking things further today, it looks as though you've made some changes to your Hub settings which may be the reason you're having the disconnections.
- Smart WiFi is disabled - This means that Channel Optimisation, Band Steering and Airtime Fairness are unavailable.
- The SSID names do not match on both WiFi bands for the primary network - This means devices cannot move between the two bands to get the best WiFi performance possible and will also affect Plume pods and stop channel optimisation from being used.
- Wi-Fi mode & channel width is 802.11g/n & HT2040 MHz - This could be causing slow speeds or connection issues due to device compatibility.
If you can return the hub settings back, this may improve the WiFi connection for you.
Keep us posted on how things go.
