Ianjaytay98
  • 16
Message 1 of 33
WiFi drops out several times an hour
For months now WiFi keeps dropping several times an hour.
Have had a replacement router, but still happening. Hub 3. Have checked cables, restarted router, reset router and no change.
I can see there are errors on the log as follows
PasswordShow
Tags (1)
lotharmat
  • 937
  • 70
  • 141
Well-informed
Message 2 of 33
Re: WiFi drops out several times an hour
can you post the Upstream and Downstream contents too!
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband (https://www.thinkbroadband.com/broadband/monitoring/quality)
Ianjaytay98
  • 16
Message 3 of 33
Thanks, here are upstream and downstream
PasswordShow
Router status
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
12027500008.440256 qam9
22107500008.140256 qam10
32187500007.540256 qam11
42267500007.540256 qam12
52347500007.540256 qam13
62427500008.140256 qam14
72507500001040256 qam15
82587500008.640256 qam16
92667500007.540256 qam17
102747500006.640256 qam18
112827500006.840256 qam19
122907500006.640256 qam20
13298750000740256 qam21
14306750000740256 qam22
153147500007.540256 qam23
163227500007.440256 qam24
17330750000740256 qam25
183387500007.140256 qam26
193467500007.340256 qam27
203547500007.540256 qam28
213627500007.540256 qam29
223707500007.840256 qam30
23378750000840256 qam31
24386750000840256 qam32
1Locked40.9260
2Locked40.9350
3Locked40.9240
4Locked40.3270
5Locked40.3730
6Locked40.9580
7Locked40.31040
8Locked40.3810
9Locked40.9520
10Locked40.9470
11Locked40.3210
12Locked40.3230
13Locked40.3180
14Locked40.9170
15Locked40.9130
16Locked40.9240
17Locked40.9110
18Locked40.3160
19Locked40.9180
20Locked40.3250
21Locked40.9150
22Locked40.3460
23Locked40.370
24Locked40.360
Ianjaytay98
  • 16
Message 4 of 33
PasswordShow
Router status
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
15370000046.5512064 qam1
23939998043512064 qam3
34620000044512064 qam2
43260000042512064 qam4
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0010
3ATDMA0000
4ATDMA0000
lotharmat
  • 937
  • 70
  • 141
Well-informed
Message 5 of 33
Hmmm - They don't look bad to be honest - Downstream power a little high!
WHat happens to any ethernet connected devices when WiFi drops?
Ianjaytay98
  • 16
Message 6 of 33
Sorry should have said, the sky box which is ethernet connection also loses access. Not strictly a WiFi issue but as you can imagine we notice it mostly due to loss of connection on phones, tablets and laptops etc
lotharmat
  • 937
  • 70
  • 141
Well-informed
Message 7 of 33
I think that does point to a problem between cab and property!
VM Staff should see this and respond!
Ianjaytay98
  • 16
Message 8 of 33
Yeah, that's what I was thinking. I'll wait for VM staff to pick up on this. Thanks for your replies
  • 22.5K
  • 2.41K
  • 4.02K
Message 9 of 33
Whilst waiting, can you test the connection on one of the laptops connected directly into the Hub by ethernet cable and see if that remains stably connected when the wifi ones drop out.
What are the various Hub lights showing/doing at the time of the drops.
If they are true network drop outs they will be obvious in the BQM - post up the link asap.
Ianjaytay98
  • 16
Message 10 of 33
John,
I was actually wrong earlier in that the sky box does remain connected during a dropout. That's the only ethernet connection. Unfortunately my laptop doesn't have an ethernet port so can't connect that. So it does look like WiFi only issue. When it happens the WiFi light on router flashes, then stops then flashes a few mins to 5 mins later before it reconnects
