on 16-11-2021 19:25
I have just upgraded to the Hub5 and have noticed that WiFi on most mobiles is constantly dropping in and out. Seems ok on my Galaxy S7, but kids Galaxy's are constantly dropping in and out. They are not happy 😊
Wired connections are fine as does WiFi to laptops. Seems to just impact mobile phones.
Anyone had similar issues?
on 16-11-2021 19:57
on 12-12-2021 17:41
Yes exactly the same.....useless on Wifi which was supposedly why this "upgrade" was launched!
on 14-12-2021 17:55
Hi there @Zalm
Thank you so much for your post and I am so sorry to hear that you are suffering with poor WiFi on these devices!
Can I just confirm do you have any other devices that are connected by WiFi, other than the phones, that are showing similar issues?
I have been able to access your account and I can see the Hub has been online for nearly month. Are you able to try a pin hole reset?
To do this push a pen etc into the 'reset' hole at the back of the Hub and hold it in for 20 seconds. It may seem simple but this can help refresh the connections.
Thank you.
on 14-12-2021 18:22
did you ever get this fixed? im having the same issue?
on 14-12-2021 19:44
Hi ash - I have tried that already. Since the "upgrade" to the new hub router WiFi on most mobile phones does not work - or works in short bursts. Other devices seem to be fine. There are not a lot of competing WiFi networks that should cause interference. I have tried to login and set up a test SSID, but there doesn't appear to be the ability to do that. Bottom line is - WiFi is worse with the new hub.
on 14-12-2021 19:45
Hi greenm54 - nope, not fixed yet. Still issues 😞
on 14-12-2021 20:23
I suspect that the mobiles are switching between the 2.4GHz and 5GHz bands because the VM hubs as shipped transmit only one SSID for both bands. You could go into the settings of the hub and split the bands giving them names like myhome-2 and myhome-5. You should then connect the mobile first to to the -5 SSID and see how it works, then to the -2 SSID and see which works best for you.
on 14-12-2021 22:22
Hi Ash,
Did the hard reset. Not a lot has changed. I have numerous devices attached, both by ethernet and Wifi. Ethernet seems fine with good speeds and data throughput, but Wifi is very unreliable. It drops altogether, or is very slow....so slow in the case of phones that they often switch to 4G instead to access data. Same for tablets. especially bad if you move more than 3 or 4 metres away from the hub. I've checked using some wifi analyser apps on my phone and it shows as a good strong signal, but it seems more to do with the data in the signal not moving freely for some reason, as if there is some sort of throttle at work on wifi.
Any other suggestions, because the Wifi is truly shocking.
Cheers
Alan
on 14-12-2021 23:30
I have six or seven connections. Six or so wireless . 2 Phones 2 iPads One Mac One Alexa
This is a similar issue I think.
But the point is my New Hub never gets my iPad above 3 whatnots on the google speed test.
Everything else works.
It is rendered useless and I depend on it.
But it works on son in laws ' SKY router.
It's a very puzzling situation I have been into the router management system , I changed it to 2 and 5 meg usage .
But we both want solutions even after self help. Ideas?
