Nivoo545
Message 1 of 8
WiFi dropping constantly
WiFi keeps dropping consistently throughout the day. Have re started the box. Am streaming from phone and the signal drops.
g0akc
  • 882
  • 82
  • 170
Well-informed
Message 2 of 8
Re: WiFi dropping constantly
Do some Wi-Fi housekeeping
  • Try using a free Wi-Fi analyser app and see if that shows anything
  • What devices?
  • Which hub?
  • How far from hub?
  • Any neighbouring hub on same channel?  Change channels
  • Device drivers all up to date?
  • Any interference sources?  Microwave oven?
  • Are wired connections OK?
  • Get own router with hub in modem mode
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
lotharmat
  • 884
  • 61
  • 125
Well-informed
Message 3 of 8
First question for me is:
Is it only WiFi that's dropping?
Nivoo545
Message 4 of 8
The WiFi switches off completely and disconnects.
I ran a WiFi check using an app and it said
Ping 28.5ms, Download 46.98mbps, upload 10.86mbps. Signal is normal.
I am unsure if having an old box would be the cause. I still have a hub that says UPC?
lotharmat
  • 884
  • 61
  • 125
Well-informed
Message 5 of 8
Have a look here:
https://www.virginmedia.com/help/virgin-media-hub-connection-status
Which hub do you have?
Zoie_P
  • 2.48K
  • 118
  • 196
Message 6 of 8
Hi Nivoo545,
Thanks for your post, I am sorry you are having issues, I have been unable to locate your account, I did notice you had and Irish email, can you please confirm if you are in the UK ?
Zoie
Nivoo545
Message 7 of 8
I don't have any of those.
It is a UPC box
Paulina_Z
  • 468
  • 15
  • 26
Message 8 of 8
Hi @Nivoo545,
Thank you for getting back to the forum.
Would you be able to confirm if you are in the UK so we can help accordingly?
Please get back to us when you can.
Paulina_Z
