WiFi dropping and unresponsive Hub 3
I have an intermittent problem where WiFi just stops working. Wired connections are still up and running perfectly but all wifi devices drop the connection and can't see it (I have a guest wifi set up and that drops as well).
If I try and log into the hub, it can be totally unresponsive (As opposed to excruciatingly slow at most other times)
Because it's intermittent I haven't been able to call VM when it's happening. I did call yesterday and effectively got 'Tough, it's working now, we won't do anything about it'!
I've done factory resets and it still happens. I pointed out it's obviously a hub thing, can't they just send a new hub as they have done in the past but the answer was a big fat NO.
I'm trying to work from home and I also have a son with Autism who can be inconsolable when his tablet loses connection during tablet time!
Is there anything I can do to get this sorted???
Thanks!
  • 25.02K
  • 1.44K
  • 3.19K
Re: WiFi dropping and unresponsive Hub 3
Try a 60 second pinhole reset on the hub to see if that stabilises the Wi-Fi thereafter
