WiFi doesn't have a valid IP configuration
Having problems with some devices not being able to join WiFi sometimes because it says the WiFi doesn't have a valid IP configuration. This problem will last around 5 hours and will happen a few times a week.
To try and solve this I have reset the router multiple times and also tried to change the DNS server but no luck so far.
Could it be something wrong with the Hub 3 that cause some devices to not connect consistently.
  • 14.73K
  • 620
  • 1.42K
Re: WiFi doesn't have a valid IP configuration
The hub just doesn't like some devices so best to get your own wireless router with 1Gb ports and use the hub in modem mode.
