RLapham
Message 1 of 10
WiFi cutting out
My WiFi has been cutting out all throughout the day and night, I can hardly steam a 20 minute show without it cutting out halfway through.
Even when I’m watching live sports the picture gets all fuzzy each time the WiFi cuts out
I had someone come out a few months back to change a few wires around, but the problem is still happening
Tags (2)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 2 of 10
Re: WiFi cutting out
What is your connection like with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
The problem with Wi-Fi is that it can be brilliant at breakfast time and useless by lunchtime and you haven't changed anything, BUT, something somewhere has changed, then you can spend hours and even days trying to find a fix for something that can be totally out of your control.
if you remove all the internal walls, electronic and electrical devices, metallic pipes and conduits and wrap the whole building in a thick lead shield you will have a good chance of getting decent Wi-Fi from a VM Hub.
Many people have accepted that the VM Wi-Fi is very poor and have purchased third party equipment that is much, much more powerful than the VM supplied kit and once set up have wondered why they waited for so long.
RLapham
Message 3 of 10
I don’t actually have any wires to connect my hub to a device, but I can tell you that it has gone down twice since I posted this question
Do you have any recommendations for third party equipment?
badmanj
  • 10
Message 4 of 10
I have the same shoddy WiFi performance and am right on the verge of just quitting VM for good... however if a premium router is easy to set up and makes a massive difference I'd do that...
Can anyone recommend some hardware?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 5 of 10
You really do need to check with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected, otherwise you won't know if it is a broadband supply problem or a local Wi-Fi problem.
If it is a broadband problem no amount of boosting will get better internet over Wi-Fi.
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 6 of 10
@badmanj wrote:
... snip ...
If you want assistance please start your own thread.
badmanj
  • 10
Message 7 of 10
Direct connection is, and always has been, superb. Just Wifi keeps cutting out...
Can you suggest a router? All I need to do is put the VM box in to modem mode and it then just connects to my own router instead, which in turn provides WiFi for the house - is this correct?
Thanks!
badmanj
  • 10
Message 8 of 10
I was just asking for the same info that the original poster asked for. Wanted to indicate my interest too. Didn't really see much point in creating a new thread to ask the exact same thing... but I guess if that's the only way...
  • 20.74K
  • 2.2K
  • 3.67K
Message 9 of 10
Badmanj:- see my posts on this thread below and do some digging - then do your own thread if you need some help deciding what to do.
https://community.virginmedia.com/t5/Networking-and-WiFi/Hub-3-0-and-Mesh-Wifi/td-p/4392650/page/2
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 10 of 10
Only you can make that decision , you know ...
Your budget,
Your local environment,
Your requirements.
