on 06-07-2021 21:01
An engineer has installed my broadband router today. While he was here the WiFi dropped out and he couldn’t connect to the router, although the router was connected to the internet. After a factory reset, the WiFi worked again and he left.
Since then, the WiFi has repeatedly dropped out on multiple devices. The wired connection works, and the Virgin troubleshooting connects to the router and confirms there are no connectivity issues. The only way to get the WiFi back is to factory reset the router, but the WiFi then drops out again after 30-45 minutes.
I think this seems like an issue with the router rather than the connection but I need someone to resolve this ASAP please as it is preventing me from working from home.
Answered! Go to Answer
on 07-07-2021 08:49
on 07-07-2021 01:06
on 07-07-2021 01:13
More Likley the internet is down altogether. Flashing green arrows on tour router? = no internet.
on 07-07-2021 01:15
@md009a3226 wrote:More Likley the internet is down altogether. Flashing green arrows on tour router? = no internet.
Why would you say that - there is no evidence for that - the OP said wired connections are fine, no mention of flashing lights.
on 07-07-2021 07:00
Does sound like a bad wifi apart of the hub.
Especially as Ethernet was fine!
I'm amazed that the engineer left it in that state - New hubs should not do that.. You probably have my old one that has been refurbished just dumped in your living room!
on 07-07-2021 07:36
Hi John,
This has been happening with 2 different iPhones and a laptop, all in the same room.
There are no flashing lights on the Hub and when I go through the Virgin troubleshooting there is no error identified with the connection.
What’s the easiest way of getting a new hub? I haven’t had the best experience with the telephone support so far!
on 07-07-2021 08:49
on 07-07-2021 13:35
@Svanwanrooij wrote:Hi John,
Is that in the same room as the Hub - in line of sight?
on 07-07-2021 13:37
Same room and in line of sight, within 1-2 metres of the Hub.
We have a technician booked to visit tomorrow so hopefully they can resolve the issue.
on 07-07-2021 13:41
