  • 32
Message 1 of 9
WiFi connection issues...
I've been having major issues with my network, ongoing but compounded by the outage for 24 hours on Wednesday. Now only wired devices only really work. On my iPhone, it says weak security. Can't log into the router cause it says someone else logged in. I called CS waited OVER AN HOUR, was told the only option was a PIN reset, he said he'd wait for me to do, then disconnected me while the router was resetting. Now I'm still stuck in WiFi limbo, once again can't log into the router, I still have weak security. I can't even change the name of the network, to see if everything can connect. I'm really at the stage of pulling my hair out, please help???
  • 11.38K
  • 888
  • 1.45K
Message 2 of 9
Re: WiFi connection issues...
It may be a good idea to carry out a factory reset on the Hub …
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once the lights are stabilised check your system again.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 24.32K
  • 1.39K
  • 3.09K
Message 3 of 9
Weak security is just Apple being over zealous of WPA2
  • 3.79K
  • 605
  • 824
Community elder
Message 4 of 9
Hi JimboUK71,
The message, "Can't log into the router cause it says someone else logged in." is usually caused by  the Virgin Connect App
You should either uninstall that app, or perform a hard reset of your router.
Keep the hub switched on and disconnect any ethernet connections, then push the reset button firmly with a paperclip or something similair. keep it pressed in for a full 60 seconds.
Wait around 10 minutes and it should revert to factory settings. You can now reconnect the ethernet cables.
This sticky post explains the weak security and what needs to be done Weak-Security
Dave
  • 32
Message 5 of 9
That's what I meant by reset, I did a factory reset when the CS operator disconnected on me. I am having the same issues!
  • 24.32K
  • 1.39K
  • 3.09K
Message 6 of 9
Are you using the Connect App?
  • 32
Message 7 of 9
I have it on my phone, yes, but I could put it into airplane mode and try again...
  • 32
Message 8 of 9
In any case, it's coming up with the same 'logged in' error
  • 24.32K
  • 1.39K
  • 3.09K
Message 9 of 9
Uninstall the app. reboot the router. Wait 20 mins.
