WiFi boosters
What is the range of the WiFi boosters? My router is in my front living room and I want to get WiFi in my shed which Is half way down my garden with a dining room and a conservatory in between.
  • 17.45K
  • 1.83K
  • 3.04K
Re: WiFi boosters
Boosters are generally poor sticking plasters and I am pretty sure they wnt help reach the shed and not worth the £3/month they will charge you for them.
Assuming that the shed has a power supply (or you can put one in) he "best" option is to get a run of exterior grade Cat6 ethernet cable and run it from the Hub outside to the shed and then plug that in to a wireless access point in there (+/- an "ethernet switch").
If for some reason that's not possible there are other options like getting a good wifi Mesh system that might reach the shed.
Or an external grade wireless access point or mesh unit - these tend to be expensive though
